sleepy06405
May 16, 2012Aspirant
Pro 6 Memory and CPU
I'll get around to running the tests eventually but so far so good using some random 2gb PC2-6400 CL6 dimms I bought on ebay awhile back for less than $50. Its fairly common memory you don't need to s...
tiranor
Jun 06, 2012Aspirant
Even if the motherboard accepts a higher FSB, beware of the potential increase in heat of the motherboard's components (NorthBridge, SouthBridge, ...)
