Sun_Tzu
Jan 25, 2013Aspirant
Pro 6
Does this support drive sizes 3Tb+? I presume it only supports SATA 2 drives? Thanks
mdgm-ntgr
Jan 25, 2013NETGEAR Employee Retired
Sun-Tzu wrote: Does this support drive sizes 3Tb+?
Yes, on RAIDiator 4.2.16 or later. If the unit ships with prior firmware you should update the firmware (requires at least one disk in place), verify the update is successful and then do a factory default (wipes all data, settings, everything) with all disks in place.
Incorrect. There are also SATA I and SATA III drives on the compatibility list. SATA III drives are compatible with SATA II ports.
