jmalmlund
Jun 18, 2012Aspirant
Pro Pioneer memory upgrade, KHX6400D2LLK2/4G
For those who want to upgrade memory I can now confirm that Kingston KHX6400D2LLK2/4G (4GB 800MHz DDR2 Non-ECC Low-Latency CL4 DIMM (Kit of 2)) works like a charm (CAS memory timings are 4-5-5-18). ...
mdgm-ntgr
Aug 08, 2012NETGEAR Employee Retired
The good thing about the Pro 6 is that it has a CPU with VT-x which is essential if you want to run 64-bit VMs in VirtualBox. This is one of the advantages of the Pro 6 over the first-gen Pro.
