dabmd
Oct 05, 2016Aspirant
Pro Pioneer power supply died. Can I use the same HD array in a RN316?
My Pro Pioneer power supply died and I am having trouble finding a replacement. If a purchase a new RN316 can I simply load the 6 disks and have it work without losing data?
- Oct 05, 2016
dabmd wrote:
... I could load the disks and then backup from the new RN316, then reformat the disks and restore the backup?
Yes. There is more information here: http://kb.netgear.com/app/answers/detail/a_id/29957
Oct 05, 2016Guru - Experienced User
Not quite.
The RN316 will mount the volume as read-only,so you can copy off the data. But the RN316 uses a completely different file system, and will have to reformat the drives.
- dabmdOct 05, 2016Aspirant
Thank you Stephen. So if I understand correctly, I could load the disks and then backup from the new RN316, then reformat the disks and restore the backup?
- StephenBOct 05, 2016Guru - Experienced User
- dabmdOct 13, 2016Aspirant
Thanks Stephen. Exactly what I needed to know.
