dabmd
Oct 05, 2016Aspirant
Pro Pioneer power supply died. Can I use the same HD array in a RN316?
My Pro Pioneer power supply died and I am having trouble finding a replacement. If a purchase a new RN316 can I simply load the 6 disks and have it work without losing data?
- Oct 05, 2016
dabmd wrote:
... I could load the disks and then backup from the new RN316, then reformat the disks and restore the backup?
Yes. There is more information here: http://kb.netgear.com/app/answers/detail/a_id/29957
dabmd
Nov 06, 2016Aspirant
No. The files are not accessible because the readynas cannot find the proper path for me to mount the shares
FramerV
Nov 06, 2016NETGEAR Employee Retired
Hi dabmd,
It appears the issue you have described requires assistance from the engineers and/or higher tier who can remote in to the NAS and fix this from the backend. It shows on your records that you still have support warranty, I suggest contacting support center and can get one of the engineers take a look at it.
Also, please register your RN316 at my.netgear.com for the warranty verification.
