AEtander's avatar
AEtander
Follower
May 17, 2012
Probably full disc, what to do?
Hello
I have a Duo with two 1 TB disc and I think my disc are full. I can see my server with the RAIDar and all lights are green, I can see my server using Finder (I am a Mac user) but I can not access it. I have restarted the server and have to skip the disccheck in order to get it to start. My humble question is, what can I do? If I get a new, bigger disc, will this do the trick? I just need to get into to be able to delete some files to get it up and running again.
Please
Anders
1 Reply
  • Are you able to get into frontview using RAIDar? What firmware are you running? Do you know what RAID configuration you are using? If you can get into frontview, you should be able to see how much space has been used up.
ProSupport for Business
