Stan78
Oct 10, 2020Aspirant
Problem installing applications
Hi there. So i bought my 2ns NAS from Netgear;) RN104 with 2x3tb WD Red installed. FW 6.10.3. Ofcourse 2nd hand but beautiful state;) Have problem though. GUI, smb, FTP, dlna, everything seems to b...
Oct 10, 2020Guru - Experienced User
How full is the OS partition?
Are you choosing the ARM version of the apps?
- Stan78Oct 10, 2020AspirantDevice is formated and empty, so like factory new.
Also restored to factory state.
Apps I'm trying to install are not from external source. On the device GUI, I go to apps, available apps list, and then install what i need. Or at least I'm trying..- StephenBOct 10, 2020Guru - Experienced User
Perhaps download the log zip, and look in apt-history.log
- Stan78Oct 11, 2020Aspirant
Hi Stephen,
apt-history says nothing,
app-install says:
Oct 11 13:44:18 NASaKrzycha fv-app-install[17720]: [transmissionr6](0%) prepare
Oct 11 09:40:13 NASaKrzycha fv-app-install[15773]: [nastools-transmission](0%) prepare
Oct 11 09:38:37 NASaKrzycha fv-app-install[15021]: [transmissionr6](0%) prepare
Oct 10 17:25:29 NASaKrzycha fv-app-install[7798]: [plexmediaserver-ros6-binaries](0%) prepare
Oct 10 17:25:19 NASaKrzycha fv-app-install[7732]: [plexmediaserver-ros6-binaries](0%) abort
Oct 10 17:25:10 NASaKrzycha fv-app-install[7732]: Process already running, pid=0
Oct 10 17:25:03 NASaKrzycha fv-app-install[7720]: [plexmediaserver-ros6-binaries](0%) prepare
Oct 10 17:00:18 NASaKrzycha fv-app-install[5037]: [transmissionr6](0%) prepare
Oct 10 16:58:18 NASaKrzycha fv-app-install[4440]: [transmissionr6](0%) prepareso also not usefull, but
install_debpkg.log says:
Install app transmissionr6
fv-app-install-utils.c:101(info) [transmissionr6](0%) prepare
fv-app-install-utils.c:106(info) Downloading [transmissionr6](0%) Retrieving file 1 of 2
fv-app-install.c:674(error) fv-app-install (transmissionr6): error code [100]: Reading package lists...
Building dependency tree...
Reading state information...
The following additional packages will be installed:
transmission
The following NEW packages will be installed:
transmission transmissionr6
0 upgraded, 2 newly installed, 0 to remove and 31 not upgraded.
Need to get 1,523 kB of archives.
After this operation, 3,474 kB of additional disk space will be used.
Err:1 https://apt.readynas.com/packages/readynasos 6.10.3/apps armel transmission armel 2.82-1
403 Forbidden
Err:2 https://apt.readynas.com/packages/readynasos 6.10.3/apps armhf transmissionr6 all 3.00.8
403 Forbidden
403 Forbidden
E: Failed to fetch https://apt.readynas.com/packages/readynasos/dists/6.10.3/apps/pool/t/transmission/transmission_2.82-1_armel.deb 403 ForbiddenE: Failed to fetch https://apt.readynas.com/packages/readynasos/dists/6.10.3/apps/pool/t/transmissionr6/transmissionr6_3.00.8_all.deb 403 Forbidden
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
fv-app-install-utils.c:121(info) [transmissionr6](0%) abort
Install app transmissionr6But why it shows 403?
