Stan78
Oct 10, 2020Aspirant
Problem installing applications
Hi there. So i bought my 2ns NAS from Netgear;) RN104 with 2x3tb WD Red installed. FW 6.10.3. Ofcourse 2nd hand but beautiful state;) Have problem though. GUI, smb, FTP, dlna, everything seems to b...
Oct 10, 2020Guru - Experienced User
How full is the OS partition?
Are you choosing the ARM version of the apps?
Stan78
Device is formated and empty, so like factory new.
Also restored to factory state.
Apps I'm trying to install are not from external source. On the device GUI, I go to apps, available apps list, and then install what i need. Or at least I'm trying..
- StephenBOct 10, 2020Guru - Experienced User
Perhaps download the log zip, and look in apt-history.log
- Stan78Oct 11, 2020Aspirant
Hi Stephen,
apt-history says nothing,
app-install says:
Oct 11 13:44:18 NASaKrzycha fv-app-install[17720]: [transmissionr6](0%) prepare
Oct 11 09:40:13 NASaKrzycha fv-app-install[15773]: [nastools-transmission](0%) prepare
Oct 11 09:38:37 NASaKrzycha fv-app-install[15021]: [transmissionr6](0%) prepare
Oct 10 17:25:29 NASaKrzycha fv-app-install[7798]: [plexmediaserver-ros6-binaries](0%) prepare
Oct 10 17:25:19 NASaKrzycha fv-app-install[7732]: [plexmediaserver-ros6-binaries](0%) abort
Oct 10 17:25:10 NASaKrzycha fv-app-install[7732]: Process already running, pid=0
Oct 10 17:25:03 NASaKrzycha fv-app-install[7720]: [plexmediaserver-ros6-binaries](0%) prepare
Oct 10 17:00:18 NASaKrzycha fv-app-install[5037]: [transmissionr6](0%) prepare
Oct 10 16:58:18 NASaKrzycha fv-app-install[4440]: [transmissionr6](0%) prepareso also not usefull, but
install_debpkg.log says:
Install app transmissionr6
fv-app-install-utils.c:101(info) [transmissionr6](0%) prepare
fv-app-install-utils.c:106(info) Downloading [transmissionr6](0%) Retrieving file 1 of 2
fv-app-install.c:674(error) fv-app-install (transmissionr6): error code [100]: Reading package lists...
Building dependency tree...
Reading state information...
The following additional packages will be installed:
transmission
The following NEW packages will be installed:
transmission transmissionr6
0 upgraded, 2 newly installed, 0 to remove and 31 not upgraded.
Need to get 1,523 kB of archives.
After this operation, 3,474 kB of additional disk space will be used.
Err:1 https://apt.readynas.com/packages/readynasos 6.10.3/apps armel transmission armel 2.82-1
403 Forbidden
Err:2 https://apt.readynas.com/packages/readynasos 6.10.3/apps armhf transmissionr6 all 3.00.8
403 Forbidden
403 Forbidden
E: Failed to fetch https://apt.readynas.com/packages/readynasos/dists/6.10.3/apps/pool/t/transmission/transmission_2.82-1_armel.deb 403 ForbiddenE: Failed to fetch https://apt.readynas.com/packages/readynasos/dists/6.10.3/apps/pool/t/transmissionr6/transmissionr6_3.00.8_all.deb 403 Forbidden
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
fv-app-install-utils.c:121(info) [transmissionr6](0%) abort
Install app transmissionr6But why it shows 403?
