atai1960
Aug 20, 2016Aspirant
Problem with disk Seagate St300DM001
Hello, I have 2 ReadyNAS; one old model NV and a more recent model 104. It's strange but I have more problems with the 104. I have added 2 new disks both 2 Seagate model ST3000DM001 and after f...
atai1960
Thank for the reply.
The disk #1 is a WD model WD10EFRX
The spin-down was already disabled
I checked the SMART but it say 0 error
The strange thing is that I don't see the temperature for this disk.
So you suggest to load the disk back on second trail?
And what about the disk on third trail? I have 142 GB data that look used but I can't see nothing.
Is there a way to restore these data?
mdgm-ntgr
Aug 21, 2016NETGEAR Employee Retired
So you don't have a backup?
- atai1960Aug 25, 2016Aspirant
No I don't have.
Anyway I have removed the disk and reload on channel 2, reformatted but when I try to create a new share on this volume I receive an error 1013030001 Commit failed.
The other disk that works on my laptop I have tried to reload but the system tell me that I have to remove because don't work.
Connected again on my laptop works fine and I see again the files copied for test before.
It look like my Nas don't like these disks.
Any suggestion?
Now I have a Nas 104 with only one 1TB disk
- StephenBAug 26, 2016Guru - Experienced User
I think you must have already lost your data, correct?
If so, the first question is whether you need some form of data recovery. Likely it would be expensive, and there is no guarantee of success.
If you aren't going for data recovery, then my advice is to check with the seller and see if you can exchange the DM drives for something else. Amazon will let you exchange if you do it quickly.
WDC WD30EFRX would be a better option, as would a Seagate ST3000VN0001. While you are at it, perhaps look at 4 TB prices and see if it makes sense to go slightly larger.
- atai1960Aug 27, 2016Aspirant
I don't care about the data lost; were only movies.
I also can't contact the reseller because it was a used disks.
But I had no answer about the disk that is still working but I can't create new shares; Do i have to consider lost also this?
For sure I will not buy any Seagate ST3000DM001 again for the future, better use WD
