PartTimer
Nov 19, 2022Aspirant
Problems mounting Netgear ReadyNAS Duo NFS share on Ubuntu
I've run into problems recently trying to access my ReadyNAS Duo v2 from a Linux box, running Unbuntu (with Plex and other duties) Everything has run fine previously for several years - but I'm n...
- Nov 22, 2022
Sandshark & StephenB
Thanks both for your quick responses. I managed to solve in the end by specifying the NFS version (using "mount -t nfs -o mountvers=3 ...") seems ubuntu & the NAS can't decide to play nicely without you explicitly telling them which version to use.
Nov 19, 2022Guru - Experienced User
Duo or Duo v2?
The labels are confusing, and frequently result in people identifying their model incorrectly.
The original Duo (called v1 here)
- says ReadyNAS Duo on the front panel
- runs 4.1.x firmware
- often has labels that say v2 on the back or bottom.
The Duo v2
- says ReadyNAS Duo v2 on the front panel
- runs 5.x firmware.
Sandshark
Nov 19, 2022Sensei
How are you mounting them, via fstab? Have you tried manually? Are you getting any error messages when you do?
Any changes made to the NAS configuration that might have had an unintended consequence?
- PartTimerNov 21, 2022Aspirant
The model is a readyNAS duo v2 running Raidiator 5.3.13
I'm mounting through fstab with:
192.168.1.102:/c/Films /films/ nfs defaults 0 0
where 192.168.1.102 is the IP address of the NAS (which I can ping from the linux box), and the /films directory is already created.
nfs-common package is also installed and updated
Not entirely sure what you mean by mounting "manually" - but if I try "sudo mount 192.168.1.102:/c/Films /films/" I get the same error "mount.nfs: mount system call failed"
- StephenBNov 21, 2022Guru - Experienced User
You are saying that SMB also fails - is that also the case from a windows PC?
Have you tried rebooting the ReadyNAS? Or downloading the log zip file and looking for errors there?
- SandsharkNov 21, 2022Sensei
Yeah, that's what I meant by manually. Try it with the -v (verbose) option and see if you get a more useful error message. Maybe try ro instead of defaults and see if that makes a difference.
If all else fails, try removing and then restoring NFS access to the share on the NAS or even disabling and re-enabling NFS all together.
- PartTimerNov 22, 2022Aspirant
