DavidtHulin
Apr 04, 2013Aspirant
Processor upgrade on 516
Hi! Will the 516 support all LGA1155 processors? Like the Xeon E3-1280V2? Also, does the 516 have active CPU-cooling? If so, how tall may it be? (On my Pro 6 I measure 55mm (ish).) I am looking ...
mdgm-ntgr
May 05, 2013NETGEAR Employee Retired
I think the CPU might be replaceable in the 516 but do note that replacing the CPU voids the warranty. Probably only some of the CPUs that can be installed in the same socket as the stock one would be compatible.
