DavidtHulin
Apr 04, 2013Aspirant
Processor upgrade on 516
Hi! Will the 516 support all LGA1155 processors? Like the Xeon E3-1280V2? Also, does the 516 have active CPU-cooling? If so, how tall may it be? (On my Pro 6 I measure 55mm (ish).) I am looking ...
mdgm-ntgr
Jun 17, 2013NETGEAR Employee Retired
Can the i7-3770K be underclocked on the motherboard in the ReadyNAS 516?
The max TDP for the i7-3770K is pretty high.
I think the i7-3770S would probably be a better choice, as its max TDP is only 10 W higher than the stock CPU.
A downside of the i7-3770 CPUs is that they don't support ECC RAM according to the specs on Intel's website.
