DavidtHulin
Apr 04, 2013Aspirant
Processor upgrade on 516
Hi! Will the 516 support all LGA1155 processors? Like the Xeon E3-1280V2? Also, does the 516 have active CPU-cooling? If so, how tall may it be? (On my Pro 6 I measure 55mm (ish).) I am looking ...
rit1
Jun 27, 2013Aspirant
Sounds like the E3-1265LV2 would be a good fit - if supported. It's a Quad with HT running at a base speed of 2.5Ghz within a 45W TDP - it also supports ECC RAM.
