DavidtHulin
Apr 04, 2013Aspirant
Processor upgrade on 516
Hi! Will the 516 support all LGA1155 processors? Like the Xeon E3-1280V2? Also, does the 516 have active CPU-cooling? If so, how tall may it be? (On my Pro 6 I measure 55mm (ish).) I am looking ...
mdgm-ntgr
Oct 13, 2014NETGEAR Employee Retired
rit wrote: Sounds like the E3-1265LV2 would be a good fit - if supported. It's a Quad with HT running at a base speed of 2.5Ghz within a 45W TDP - it also supports ECC RAM.
That's the one we use in the 716X.
The E3-1265LV2 should work though do note that CPU upgrades void the warranty.
