Tatsu
Dec 28, 2011Aspirant
PSU fan replacement for Readynas Pro
Hi there, I have RNDP6350 and unfortunately PSU fan very loud and the sound it makes is similar to tractor. I use it as my home office backup and multimedia streamer so I have to change the faulty...
mdgm-ntgr
Dec 28, 2011NETGEAR Employee Retired
+1. I'd also recommend taking the warranty replacement for the whole chassis.
Voiding the warranty by replacing it yourself with a 3rd party part that may/may not work and may damage your hardware is not a good solution.
