victorypoint
Mar 12, 2012Aspirant
PSU for NV still available?
Hi folks. I have an old school Readynas NV that was still working fine until this morning when the PSU failed. Are replacement PSU's still available? It looks like the PSU may be the same one used in ...
mdgm-ntgr
Mar 12, 2012NETGEAR Employee Retired
Are you sure it's the PSU that's failed?
If and only if you don't smell a burning smell or see burnt capacitors on the PSU, a failed PSU might not be the problem. Do you use the power timer? If so take a look at this: http://www.readynas.com/forum/faq.php#I%27ve_enabled_the_schedule_Power-Off%2FPower-On_option_on_my_NV%2C_but_now_I_cannot_power-on_my_ReadyNAS._What_should_I_do%3F
