dapo
May 29, 2018Follower
psu in netgear 3312 permanent amber light and buzzing sound
good day,
just got a new netgear readynas rr3312 after unboxing and powering i got a permanent amber light at the back of the chassis where the psu's 2 are installed on the extreme left of the psu...
JohnCM_S
May 29, 2018NETGEAR Employee Retired
Hi dapo,
Welcome to the Community!
Have you tried shutting down the system and then remove and re-insert the PSU2? You can also try inserting the PSU2 to the PSU1 slot and see if the issue will still follow.
JohnCM_S
Jun 01, 2018NETGEAR Employee Retired
Hi dapo,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
