jcnalda
Jan 05, 2017Aspirant
Psu rnd4425
good afternoon I have a rnd4425 and the psu has broken and within 2 weeks I do not get another one. Does anyone know if I can do another one with a pc power supply until the other one comes?
Jan 05, 2017Guru - Experienced User
jcnalda wrote:
good afternoon
This is an NV+ v1 (with -100 at the end of the part number, running 4.1.x firmware)?
If so you can temporarily use an ATX supply (external to the NAS) using a 20-pin ATX extender cable to get the power into the NAS. You do need to modify the pinout of the extension cable though - here's a diagram: http://www.readynas.com/download/archive/pdf/ReadyNAS_PSU_pinout.pdf
- jcnaldaJan 05, 2017Aspirant
Good afternoon thanks for the reply. But would not you have something more graphic? Something I can put into practice myself.
Where can I get the two yellows to replace with blue and white? Of the 4-pin connector?
- bedlam1Jan 05, 2017Prodigy
Presumably you need to "butcher" the extension cable (to preserve the ATX PSU for "normal" use or return to the supplier when your replacement is received)
Then ON THE EXTENSION CABLE cut the blue cable coming from the PSU and tape it, cut the white cable coming from the PSU and tape it, cut the yellow cable coming from the PSU (in the middle to give plenty to work with) and join Yellow from PSU to Yellow, Blue and White going to NAS
The 20 pin ATX extension cables are very cheap.
Maybe wait for another post on my thinking as I am no expert
Thank you very much for the answer but in this video http://www.evercase.co.uk/CompatibilityListReadynas.htm that saw coke just cutting the blue cable it is right how do I do?
thank you very much
