bnchester
Jul 19, 2014Aspirant
Put disks from ReadyNAS NV+ into 314 chassis? #23588643
I have an NV+ with 4 disks whose chassis appears to be fried. I am looking at the ReadyNAS 314 diskless and would plan to simply install the disks there and start it up. Will that work? Thanks!
mdgm-ntgr
Jul 19, 2014NETGEAR Employee Retired
No, but if you have somewhere to backup your data to if you buy a 314, assuming your array is fine support should be able to try to recover your data for you.
Buy a 314, and one new disk to put in it, open a support case and let me know the case number. Support will be able to advise you of steps to take.
