bnchester
Jul 19, 2014Aspirant
Put disks from ReadyNAS NV+ into 314 chassis? #23588643
I have an NV+ with 4 disks whose chassis appears to be fried. I am looking at the ReadyNAS 314 diskless and would plan to simply install the disks there and start it up. Will that work? Thanks!
bnchester
Jul 20, 2014Aspirant
So mdgm, you're saying that with a 314 chassis and one fresh disk there will be a process to restore the data on the 4 XRAID disks from the old unit (assuming they're OK)? I have a backup of the data (a couple fo days old), but I was hoping to be able to simply remount the existing array in a new chassis.
I did this before but it was from an NV+ to an NV+, and it worked. You're saying that won't work going from an NV+ to a 314?
Thanks,
Barry
Thanks,
Barry
