bnchester
Jul 19, 2014Aspirant
Put disks from ReadyNAS NV+ into 314 chassis? #23588643
I have an NV+ with 4 disks whose chassis appears to be fried. I am looking at the ReadyNAS 314 diskless and would plan to simply install the disks there and start it up. Will that work? Thanks!
mdgm-ntgr
Jul 26, 2014NETGEAR Employee Retired
Your NV+ has a 3 year warranty which has not yet expired (assuming the data of purchase on your registration is accurate). You should probably ask for an RMA for your NV+. Then transfer your data across your network to the 314.
