haddendue
Apr 25, 2016Aspirant
QLogic FC HBA for Readynas 4200 V2?
Hi all,
i have an Readynas 4200 V2 and i want to add a QLogic FC HBA to the free PCIe slot to make a direct connection to my backup server. Is it possible to use this card with this readynas?
- mdgm-ntgrNETGEAR Employee Retired
We don't support using 3rd party cards. If you are an advanced user you might be able to get something to work using SSH particularly if you are running OS6 (unsupported but it will run on your NAS). You would need a solution that works with Debian Linux.
- JennCNETGEAR Employee Retired
Hello haddendue,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.The Netgear community looks forward to hearing from you and being a helpful resource in the future
