debm
Jan 31, 2016Aspirant
question about HDD Freecom XS
Hello I am new here and I am interested in buying a READYNAS 102, however I am thinking of using one HDD Freecom XS (for the moment this is an external HDD but I would recover the Freecom drive) 2 ...
BrianL2
Jan 31, 2016NETGEAR Employee Retired
Hi debm,
Are you going to use this HDD as the main (internal) drive? or to use the said drive and recover its data using the RN102? If this is what you meant, here's a post that you can refer to.
Looking forward to your response.
Kind regards,
BrianL
NETGEAR Community Team
Feb 01, 2016Guru - Experienced User
Use the Freecom as your backup (and yes, you do need a backup). Not all drives work with RAID, and Netgear will deny support if the drive isn't on their published hardware compatibility list.
The best option is to get a new drive for the RN102 - ideally a drive designed for NAS. I recommend the WDC "red" drives, though other posters here have had good experiences with the Seagate VN drives. Don't get the Seagate DM drives (or the Seagate archival drives).
Note that if you want RAID redundancy you'll need two drives of equal size.
- debmFeb 01, 2016Aspirant
thanks for the reply very usefull to me
