Andy101
Mar 29, 2024Aspirant
Question about Volumes in a ReadyNAS 104
I have a ReadyNAS 104 with 4 1TB disks in. I had to remove one to test something, but upon replacing it, the drive is showing up black. My volume data is showing as Degraded. I've tried formatting t...
- Mar 29, 2024
Best approach to this is power down the NAS before removing the disk, and leave it powered down until after the disk is put back.
Andy101 wrote:
I've tried formatting the drive and hitting the Global spare button.
Formatting should have started a resync. No idea why you would hit the spare button if the goal was to put it back in the array.
Are you running X-RAID or FlexRAID? (If there is a green stripe on the X-RAID control, you are running X-RAID).
You could try removing the disk again and then unformatting it on a Windows PC. Go into the windows disk manager and remove every partition (Windows calls them volumes). Then hot-insert the disk into the NAS, and see if it starts to sync.
Mar 29, 2024Guru - Experienced User
Andy101
Apr 01, 2024Aspirant
Thanks Stephen,
That did the trick.
Thanks for your help.
