WhySoManyUserna's avatar
Apr 17, 2019
Question: replacing ReadyNAS Ultra 6 RNDU6000, like-for-almost-like replacement model?
I have a ReadyNAS Ultra 6 RNDU6000, with the following disk set up. I am giving the unit away to somebody heading off to college, mulling over replacement models. Suggestions?   Three Wester...
  • StephenB's avatar
    Apr 17, 2019
    The RN400 series is the platform that is most similar to the Ultra, though you should probably look at the RN500 and RN600 also.
    One question is whether you really need 6 bays.  Your current data volume is 6 TB, you could easily go with 4 bay model with larger disks (or even a 2 bay).
    If you do want a 6 or 8 bay model, then the options are the RN426, RN428, RN526, RN528, RN626, RN628.
    Note you won't be able to migrate your existing disk drives and preserve your data.  A new NAS will need to reformat them.
ProSupport for Business
