Sootchucker
Nov 12, 2012Aspirant
Quick question on 3rd Drive for NV+ V2
Hi Guys, a quick question please. I currently have an NV+ V2 with two pieces WD 3TB RED Sata 6gbs HDD's. I'm in the process of imaging all my DVD's so I can put the originals in the loft out of the...
Nov 12, 2012Guru - Experienced User
The default setup is XRAID-2.
-You can install one drive (adding another later on if you wish).
-Adding another 3 TB drive would give you another 3 TB of storage. Adding two 3 TB drives would give you 6 TB more.
