fitzski
Jun 12, 2013Aspirant
Quick question... USB 3.0 upgrade?
Think I know the answer to this, but figured I'd ask anyway... Is there any way I can add USB 3.0 to my RNDP600E (Pro Pioneer)?
mdgm-ntgr
Jun 12, 2013NETGEAR Employee Retired
I don't think so.
You could however consider the new ReadyNAS OS devices such as the RN316 and RN516 which have two USB 3.0 ports on the rear as well as some eSATA ports :)
However do note that due to the different filesystem you would need to transfer your data e.g. across your network.
