davidr1
Feb 10, 2014Luminary
Radiator-x86--V4.4.26 - says wrong architecture
Ultra 2 Pro 2 I downloded RAIDiator-x86-V4.2.26.zip to do a local upgrade on both the above. Verifying the image reorts "Update file is not valid for this architecture". I have downloaded tw...
Feb 11, 2014Guru - Experienced User
Personally I think Frontview should check for that - it knows the file extension, so it would not be difficult.
