stgeorge
Dec 30, 2013Guide
RAID expansion question
So I have a pro6 currently fitted with 3X1TB hard drives in some form of the default RAID setup. I have 3 empty bays. I also have a Duo that I use as a media server, specifically for movies, and i...
Dec 31, 2013Guru - Experienced User
If the resync is finished, try rebooting the duo. You may need to do this more than once.
