klokkaren's avatar
klokkaren
Follower
Feb 06, 2016
RAIDar does not discover ReadyNAS, NV+ v2, LAN-cable
I bought this unit a couple of year ago and haven't used it because I ran into trouble then. Now I really need to backup my macbook pro, before installing a new OS.    I am totally green when it co...
  • StephenB's avatar
    Feb 07, 2016
    klokkaren wrote:
    When booting up it said 192.168.168.168
    Yes.  That is because your Mac isn't a router.
    The easiest way is to connect both your NAS and Mac to your router with ethernet.
    Or you can follow DaneA's procedure and set a compatible static IP address on the mac (192.168.168.100 will work).
ProSupport for Business
