rg2go's avatar
rg2go
RAIDAR fallback version for MacOS: 4.3.8 worked for me
Just got a new iMac, runnng macOS Sierra 10.12.4 Fired up my ReadyNAS+ (after about a year powered down) to pull in some backed up photos.  Installed latest downlkoad RAIDAR (6.x) from download sit...
  • rg2go's avatar
    rg2go
    Jun 12, 2017
    Hello Jenn,
    I decided to stay with the version 4.3.8 for MacOS since it is still working for me.
    I do not have time at the moment to debug why the latest version 6.x did not work.
    As you said, perhaps I should have re-started the iMAc after installing Java 7.
    If I run into problems which require use of 6.3, I will look into that further,
    Thanks for your help.
ProSupport for Business
