ThomColeman
Oct 21, 2012Aspirant
Raidiator 4.2.22 (x86) fan noise too loud on Ultra 6
I have a pair of Ultra 6 boxes in my living room. Normally, these boxes have their drives spun down due to inactivity, and the fan noise from the boxes is inaudible even when standing next to the box...
Oct 21, 2012Guru - Experienced User
You should probably try the fan calibration procedure first. If that doesn't work, you could try downgrading back to 4.2.21 or 4.2.20, and see if you get the old behavior.
