Anton_
Aug 31, 2020Tutor
RAM Upgrade, Fan replacement, UPS, RNDU4000
I want to upgrade my RAM in my RNDU4000. Comes with 1GB.
What is the maximum for RNDU4000? Is it one or two modules?
Ive read that the maximum is 4GB for this unit. Is that correct?
1x4GB, 2x2GB? 600Mhz or 800Mhz? SO-DIMM DDR2 or SO-DIMM DDR3?
Then i also want to replace the fan in this unit, it is annoying loud.
What are the size and what can i replace it with? Any Noctua fan?
Also looking for a small and non-expensive UPS only for this machine.
It need to have one feature that it can shutdown the NAS automaticlly.
So i guess the battery can have like 10min of power or something?
I have looked some on APC and Powerwalker.
1x4GB, 2x2GB? 600Mhz or 800Mhz? SO-DIMM DDR2 or SO-DIMM DDR3?The Ultra 4 will take up to 4 GB, but I believe it only has one slot.
200-Pin DDR2 SODIMM DDR2 667 (PC2 5300) should work.
- Anton_Tutor
Thank you, i will look into it!
G.Skill have compatible RAM.
I have looked some on APC and Powerwalker.I've gone with larger UPS myself - 1200 to 1500va. Hopefully someone who's used smaller models will be able to make a recommendatoin.
- Anton_Tutor
Ok, what model are you using? How have you it setup for the NAS?
I've gone with CyberPower - not necessarily saying they are the best choice, but they have worked for me. The most recent purchase was the CP1500AVRLCD. Options here do depend somewhat on your power (I'm in the US). APC is certainly a popular choice, and there are certainly others (Eaton being one I recall off-hand).
On the setup, all you need to do with a single NAS is connect the USB cable on the UPS to the NAS (and of course also connect the NAS to the UPS power). With multiple NAS, you can monitor the primary NAS (directly connected to the USB) over the network - making sure that the switch (or router) is also protected by the UPS.
