Anton_
Aug 31, 2020Tutor
RAM Upgrade, Fan replacement, UPS, RNDU4000
I want to upgrade my RAM in my RNDU4000. Comes with 1GB. What is the maximum for RNDU4000? Is it one or two modules? Ive read that the maximum is 4GB for this unit. Is that correct? 1x4GB, 2x2GB? ...
Aug 31, 2020Guru - Experienced User
1x4GB, 2x2GB? 600Mhz or 800Mhz? SO-DIMM DDR2 or SO-DIMM DDR3?
The Ultra 4 will take up to 4 GB, but I believe it only has one slot.
200-Pin DDR2 SODIMM DDR2 667 (PC2 5300) should work.
- Anton_Aug 31, 2020Tutor
Thank you, i will look into it!
G.Skill have compatible RAM.
