BMac2021
Aug 30, 2026Tutor
Accessing files via remote login
Good morning all! Hope this should be a quick solution... I login remotely in to my NAS. I sign in and it will show my file folders but nothing in the file folders when I click on them. I am sig...
- Aug 30, 2026
BMac2021 wrote:
I login remotely in to my NAS. I sign in and it will show my file folders but nothing in the file folders when I click on them. I am signing in under a USER which I have given read/write access to the folder in FILE ACCESS as well as NETWORK ACCESS.
When I sign in under ADMIN, I can see all the files in the folders.If you want to propagate your changes to "File Access", then you need to use the RESET control on the File Access page. That will apply your file permissions recursively to all files/folder in the share.
Aug 30, 2026Guru - Experienced User
BMac2021 wrote:I login remotely in to my NAS. I sign in and it will show my file folders but nothing in the file folders when I click on them. I am signing in under a USER which I have given read/write access to the folder in FILE ACCESS as well as NETWORK ACCESS.
