rodcrit's avatar
rodcrit
Luminary
Nov 11, 2021
Antivirus scanner definition file update failed
8 days ago I started to get message "Antivirus scanner definition file update failed due to download failure. Check your Internet connection. "  it continuous to show every day. This happend a coupl...
  • rodcrit's avatar
    rodcrit
    Nov 12, 2021
    Well that was interesting.    had to change internet adapter port because I inadvertantly disabled the port I was on.   having changed the port, could now upload the 6.10.6 system update.
    installed the update and lo and behold all is well.   got an immeadiate antivirus file download and a number of other things that had been happening ( Plex not being able to be accessed for one) are now working ok again.
    as I said in another area  -  never to late to learn.   but would rather not have to :-)
    Rodcrit
