RockyArnold11
Oct 06, 2017Aspirant
archive
Have an RN214 with 4 HDs (8Tb) matched-up with 4 TiVos. Set it up successfully using full JBOD on each HD in order to maximize storage of videos and not desiring the backup features. Didn't archive...
- Oct 11, 2017
Hi RockyArnold11,
I believe your existing online case got escalated to the higher tier of NETGEAR Support. If ever your ReadyNAS is not yet on the latest firmware v6.8.1, I suggest you to update it to the latest v6.8.1. Though it does not say on the release notes that it includes a fix or enhancement which involves archiving from TiVo, this might help. You can download the latest firmware v6.8.1 here.
Also, you may follow-up on your existing online case with NETGEAR Support since it has been escalated to the higher tier.
DaneA
NETGEAR Community Team
steve_t
Oct 07, 2017Master
You might find better help in the ReadyNAS section as opposed to this Arlo security camera section. Hope they can help :)
