RcR
Sep 19, 2015Tutor
Can't access admin panel (ReadyNAS 102)
After turn on my NAS gets IP address 192.168.2.25 I can ping it from my PC. Power led blinks constantly after power up, I can turn it off only by unpluging power cord. I can't access admin panel by b...
- Sep 19, 2015
Hello RcR,
Welcome to the community!
The OS and data are saved to the disk that is inserted to the ReadyNAS chassis. Without any disks, it is useless, you will not be able to access its admin page. SSH is also disabled by default so if you want to access it via SSH, you need to get to the admin page first then enable it from there. The Telnet access is designed for engineering and L3 support.
JennC
Sep 19, 2015NETGEAR Employee Retired
Hello RcR,
You are most welcome.
By the way, the NAS formats the disks that are inserted to ReadyNAS file system format so, make sure there is no partitions on it. Make sure to back up the files saved to it too. It has to be empty and no partitions.
If the ReadyNAS fails to install with the disks, factory reset the ReadyNAS with the disks in. This will force the NAS to format the disks and install the OS from flash memory of the NAS to the disks.
RcR
Sep 19, 2015Tutor
In fact this is what I did with my 2 old Samsung drives - backup old data, next initial full format in linux PC to ext32, than at first try to initialize with RAIDar (destroy option) with no success overnight (around 8-10 hours). In the morning factory reset with the drives in (gave up after 4-5 hours without success).
Anyway Your informations calmed me (now I can assume the blame is on uncompatible drives) and hope all will be fine when new drives arrive on tuesday (will post info here of how it ends - just to leave knowledge to other forum users)
Regards
