RcR
Sep 19, 2015Tutor
Can't access admin panel (ReadyNAS 102)
After turn on my NAS gets IP address 192.168.2.25 I can ping it from my PC. Power led blinks constantly after power up, I can turn it off only by unpluging power cord. I can't access admin panel by b...
- Sep 19, 2015
Hello RcR,
Welcome to the community!
The OS and data are saved to the disk that is inserted to the ReadyNAS chassis. Without any disks, it is useless, you will not be able to access its admin page. SSH is also disabled by default so if you want to access it via SSH, you need to get to the admin page first then enable it from there. The Telnet access is designed for engineering and L3 support.
RcR
Sep 19, 2015Tutor
In fact this is what I did with my 2 old Samsung drives - backup old data, next initial full format in linux PC to ext32, than at first try to initialize with RAIDar (destroy option) with no success overnight (around 8-10 hours). In the morning factory reset with the drives in (gave up after 4-5 hours without success).
Anyway Your informations calmed me (now I can assume the blame is on uncompatible drives) and hope all will be fine when new drives arrive on tuesday (will post info here of how it ends - just to leave knowledge to other forum users)
Regards
RcR
Sep 25, 2015Tutor
On tuesday I Installed 2 new 1 TB WD red drives, started with factory reset, NAS was up and working after 15 minutes (I also changed ReadyNAS 102 to new one on monday, but it wasn't working with my old hdd too). So the fault was on my old uncompatible drives and everyone who is going to buy ReadyNAS 102 should have in mind that possibly he will have to invest in new drives too. Anyway with new hdd NAS works very well up to now, configuration was fast and simple. Thanks for all support, I think the case is fully solved now.
Regards
