mahfooz
May 07, 2017Aspirant
Firmware 6.7.1 Broken my 1 Network Interface and lots of other problems
I have updated my firmware and got following problems 1- It has broken 1 of my network interface. 2- I am unable to see any available apps. 3- I was unable to turn off ready cloud 4- Clicking on ...
- May 21, 2017
1) How do I point it myself to the correct drive should this happen again ?
1. Create new .apps and home subvolume in new volume, (For example, MyData is new volume)
a. Access NAS via SSH, then run below two commands,
btrfs subvol create /MyData/.apps
btrfs subvol create /MyData/Home
2. /lib/systemd/system/apps.mount and /lib/systemd/system/home.mount were pointing to the NEW volume using vimtiny command, (For example, MyData is new volume in below config)
root@NAS:/# cd /lib/systemd/system
root@NAS:/lib/systemd/system# cat apps.mount
[Unit]
Description=Apps Directory
After=local-fs.target
Before=multi-user.target[Mount]
What=/MyData/.apps
Where=/apps
Type=none
Options=bind[Install]
WantedBy=multi-user.target
root@NAS:/lib/systemd/system# cat home.mount
[Unit]
Description=Home Directory
What=/MyData/home
Where=/home
Type=none
root@NAS:/lib/systemd/system#3. Run OS Reinstall,
2) Should I not use my previous saved config file ? (last time I used this file and it has braked everything again)
You can't restore old config file because mount path is changed, if use old config, it will point to old volume in config file.
mdgm-ntgr
May 10, 2017NETGEAR Employee Retired
Both the installed apps and available apps depend on the apps mount.
evan2
May 10, 2017NETGEAR Expert
Mdgm mean is
there are all avaliable apps on a volume, but the volume is on your a removed disk,
so all available app disappeare,
for example, my system (default setting), all availabe apps (in /apps/.freeapp) is on data volume (md127)
if data volume removed, all availabe app will disappear,
Please run os-reinstall, all available apps (.freeapp folder) will come back, it will put on the first volume in your NAS.
/dev/md127 on /data type btrfs (rw,noatime,nodiratime,nospace_cache,subvolid=5,subvol=/)
/dev/md127 on /apps type btrfs (rw,noatime,nodiratime,nospace_cache,subvolid=258,subvol=/.apps)
/dev/md127 on /home type btrfs (rw,noatime,nodiratime,nospace_cache,subvolid=257,subvol=/home)
/dev/md127 on /run/nfs4/home type btrfs (rw,noatime,nodiratime,nospace_cache,subvolid=257,subvol=/home)
root@nas-43-D6-80:/# cd /apps
root@nas-43-D6-80:/apps# ls -al
total 16
drwxrwxr-x 1 root root 98 May 8 20:30 .
drwxr-xr-x 1 root root 174 May 8 20:28 ..
dr-xr-xr-x 1 root root 0 May 8 20:28 DO_NOT_DELETE
drwxr-xr-x 1 media root 0 May 8 20:30 .forked-daapd
drwxr-xr-x 1 admin admin 1212 May 8 20:28 .freeapps
drwxr-xr-t 1 root root 16 May 8 20:30 .readydlna
drwxr-xr-x 1 root root 12 May 8 20:28 .xdg
root@nas-43-D6-80:/apps# cd .freeapps
root@nas-43-D6-80:/apps/.freeapps# ls
ajaxplorer joomla nzbget-rn shellinabox
asterisk-app kernelplus oraynewph sickbeardr6
automatic koken oscommerce sickrage
baikal limesurvey osticket smbplus
bindr6 linux-dash photos2 subversion-ntgr
bzeeetr6 loganalyzerr6 phpmyadminr6 sugarcrm
couchpotato memeoc1 phpr6 surveillance
ddclientr6 monsta phpsysinfo tftpr6
dnsserver mysqlr6 piwigo tinyrss
drupal nastools-gateone prestashop transmissionr6
dvblink-tv-server nastools-istatserver pydio twonky
elc nastools-logitechmediaserver pythonr6 utserver
glpi nastools-netdata qbittorrentr6 virtualhere
htop nastools-transmission recollweb vpnserver
idrive nastools-zoneminder resilio-sync
istat neromediahome selfoss
- mahfoozMay 10, 2017Aspirant
Thanks for the explanation Evan otherwise what mdgm has written was shoot out above from my head (couldn't able to understand)
Re installing of the OS is the first thing I have done even before posting it here but that did make any difference
I can do that again if you think it will/can fix or atleast worth trying.
- evan2May 11, 2017NETGEAR Expert
Please try os-reinstall again and check if all available apps come back,
Note: I tried to delete .freeapp folder in backend yesterday, all available will disappear in admin GUI, then run os-reinstall, they come back.
if don't come back, please let me know, I will check with developer how to do?
below link is how to do OS reinstall in boot menu for RN314,
https://kb.netgear.com/22891/How-do-I-access-the-boot-menu-on-my-ReadyNAS-104-204-214-or-314
- mahfoozMay 11, 2017Aspirant
just done OS reinstall and still nothing in available apps :smileysad:
- StephenBMay 11, 2017Guru - Experienced User
Does your NAS have internet connectivity (including DNS)?
I can able to access my NAS using readycloud account over internet.
So I guess I do have internet in my NAS
- evan2May 12, 2017NETGEAR Expert
I reproduced you app not available issue, setp as below,
1. Boot system with a volume ( the volume is on disk1)
2. Change to flex-raid,
3. Insert the second disk, destory old volume on it, the create volume2 on disk2,
4. Remove disk 1, available app will disappear, it can't come back if do os-reinstall because there is not .apps subvol in new volume and mount path is still using old volume.
Please follow setps to fix it,
1. Enable SSH in admin GUI (SSH is in System/Settings screen)
2. Access NAS via SSH (User is root, password is same as login admin GUI)
3. Check volume name you want to put available app using mount command,
please see below my volume's name is data
root@nas-43-8D-A6:# mount
4. Create .apps and home in in your volume
Note: my example volume is data, you can change to your volume's name
root@nas-43-8D-A6:/# btrfs subvol create /data/.apps
Create subvolume '/data/.apps'
root@nas-43-8D-A6:/# btrfs subvol create /data/home
Create subvolume '/data/home'5. Open /lib/systemd/system and change path to new volume in apps.mount and home.mount file
root@nas-43-8D-A6:/lib/systemd/system#vim.tiny apps.mount
[Unit]
Before=readynasd.service
ConditionPathIsDirectory=/data/.apps
[Mount]
What=/data/.apps
Where=/apps
Type=none
Options=bind
[Install]
WantedBy=multi-user.targetroot@nas-43-8D-A6:/lib/systemd/system#vim.tiny home.mount
[Unit]
ConditionPathIsDirectory=/data/home
[Mount]
What=/data/home
Where=/home
Type=none
Options=bind
[Install]
WantedBy=multi-user.target6. reboot system,
you will find apps and home vill be mount
/dev/md127 on /apps type btrfs (rw,noatime,nodiratime,nospace_cache,subvolid=258,subvol=/.apps)7. run os-reinstall, all available will be back.
- mahfoozMay 12, 2017Aspirant
SSH is unable to start and giving error as showing below
:smileysad: :smileysad: :smileysad: :smileysad: :smileysad: :smileysad: :smileysad:
- mahfoozMay 14, 2017Aspirant
Look like Netgear Guru's has exausted with all of their tips, tricks and technical knowledge
Still waiting for them to tell me what's next as i would still say
NETGEAR LATEST FIRMWARE SUCKS AND HAS BROKEN MY NAS.
- evan2May 15, 2017NETGEAR Expert
Sorry for reply so late,
Is DLNA enabled on your NAS? check it's status in Admin GUI System/Settings/ReadyDLNA,
if DLNA is enable, please disable DLNA firstly in Admin GUI then enable SSH,
because DLNA still use apps subvol, if there is not volume, it affect all services enable.
if it still can't enable SSH after disable DLNA,
Please enable Secure Diagnostic mode in Admin GUI system/Settings/Support, then PM me 5 digitals, let me remote to access.
- mahfoozMay 16, 2017Aspirant
Hi Evan,
I have tried as you said but still unable to create volume described by you in previous post.
I have open the port and PM'ed you the code.
Please have a look and let me know if you need any thing fruther from me or when to close the port.
Cheers
- mahfoozMay 17, 2017Aspirant
Hi Evan,
I have PM'ed you about my issue again.
You did a awesome job and it was fixed but as soon as I restore my configuration to restore my access and account settings it revert back to broken :smileysad:
I have tried to follow your command to restore but either the sequence given by you is not correct or command is not comple or for some other reason I was unable to run most of the command and checking the file is not showing .app and home.
Can you please advice if my backup config file is having broken settings?
Please help me once again to fix this Please ...... please..........please..........
also if you can give me exact sequence and command of how to fix this myself.
I have open the port for you to login and pm'ed you port id
Thank you very much and Kind Regards.
- jak0lantashMay 17, 2017Mentor
mahfooz wrote:You did a awesome job and it was fixed but as soon as I restore my configuration to restore my access and account settings it revert back to broken :smileysad:
That seems like a bad idea.
- mahfoozMay 18, 2017Aspirant
OK I KNOW I SHOULDN'T BE USING MY CONFIG FILE PERHAPS.............NO ONE TOLD ME FROM NETGEAR THOUGH
BUT
CAN EVAN OR SOME ONE FROM NETGEAR BOTHER TO FIX THIS ONE AGAIN FOR ME ????????????????
OR GIVE ME ALL COMMANDS STEP BY STEP IN SEQUENCE TO FIX THIS
- jak0lantashMay 18, 2017Mentor
First, don't be yelling.
It's not a matter of restoring the config. It's a matter of restoring the config AFTER somebody fixed your NAS.
There are steps in this thread already, and you're always welcome to backup your data, Factory Default your NAS and reimport your data.
Thanks for most unhelpful person in this form from <jak0lantash>
You have never helped me but you are trying to show attitude.
You never supported me but you still want to show me the manners
THAT'S MOST AWEFUL AND PATHATIC.
I know some one helped me but it doesn't mean you can't and shouldn't be helping me again.
You have never told me to not to restore my config file again else it will break again.
THE COMMANDS HERE DOESN'T MAKE SENSE....... I HAVE TRIED AGAIN AND AGAIN AND AGAIN BUT DOESN'T GO WELL WITH MY NAS
IS THIS IS HOW YOU TREAT YOUR CUSTOMER BUYING BUSINESS PRODUCT.
DON'T LET ME START THIS ON YOUR FACEBOOK AND TWEETER THAT HOW BAD AND PATHATIC YOUR REPLY WAS
mahfooz wrote:IS THIS IS HOW YOU TREAT YOUR CUSTOMER BUYING BUSINESS PRODUCT.
Who's customer? I don't work for NETGEAR.
Let's see if somebody is willing to work on fixing the NAS one more time.
THEN SHUT YOUR ASS AND BUZZ OFF!!!!
We are having some serious business here.
- evan2May 21, 2017NETGEAR Expert
Sorry! I checked my email every day, but don't see your email in My mail list,
for user account,
they are home user and put in home subvol,
but older volume is deleted, and I created new home subvol in new volume, the path is changeed,
so your access and account settings it revert back to broken,
and you have PM to Mdgm, please let Mdgm help you check the home issue.
- mahfoozMay 21, 2017AspirantI have emailed to him but he is not answering would be thankful to you if you can fix while he might be busy.
- mahfoozMay 21, 2017Aspirantit's a same port if you want to login
