Peter_Zulof
Mar 21, 2016Guide
Import users from active directory
HI All, I have a problem importing users from active directory, despite that the operation completed successfully but i cant found users after authentication succeed. It was working fine, then i...
Peter_Zulof
Apr 10, 2016Guide
It was working on the same version 6.4.2 but i hade to format the domain, then i couldn't import users anymore.
Best
sviiimue
Apr 11, 2016Aspirant
thank you Peter_Zulof
i tested a second unit, factory reseted and it doesn't work either.
Then i tested it with a second, test lab, domain controller 2012R2 and it worked neither.
The problems with the netgear nas drive me crazy and I probably will sooner or later exchange and sell off all netgear devices.
edit: Firmware on both 6.4.2.
