gso
Apr 14, 2020Guide
iTunes sync
Currently I have my iTunes music files on the NAS. I manually copied them to the music folder in ReadyCLOUD. My main source for these files is in my iTunes/music folder on my Mac. The music is outdat...
Apr 17, 2020Guru - Experienced User
gso wrote:
I'm "scanning library" now in the Plex app. I that the same as "rebuilding?
Yes.
After that you might need to fix some of the matches.
gso
Apr 26, 2020Guide
Maybe I should open a new discusiion but since you all seem to be familiar with my previous issue I thought that maybe you could be helpfull with this.
I sync my Sonos and Plex music libraries with my NAS Music being the source. Both Plex on the web and Sonos are identical but they seem to be syncing with the ReadCloud Plex app & not the NAS Music, don't know why? Any help?
- gsoApr 26, 2020Guide
Actuall the Sonos veersion seems fine but using Plex on the Web isn't. MyIOS apps are fine. Maybe updating Metadata?
I did like you said and deleted my Music folder in the NAS/ReadyCloud. Then Cloned from Carbon Copy Cloner back into the NAS directly from my iTunes/Music folder. My ReadyNAS & iTunes have the same files but there is a folder called "Various Artists" which I moved all of the data to the root level, so the folder is now empty in both. But in Sonos & Plex & on IOS apps there is 169 albums (the same albums are in the root level.
I moved the data to the root level of the Itune folder before Cloning to NAS.
- StephenBApr 27, 2020Guru - Experienced User
I still don't understand what you think is wrong. How many albums should there be?
- gsoApr 27, 2020Guide
Never mind. It's just iTunes way of saying there are several artists. I was concerned there were multiple copies of sam music but it isn't so. Thx.
