gso
Apr 14, 2020Guide
iTunes sync
Currently I have my iTunes music files on the NAS. I manually copied them to the music folder in ReadyCLOUD. My main source for these files is in my iTunes/music folder on my Mac. The music is outdat...
Apr 26, 2020Guru - Experienced User
gso wrote:
but using Plex on the Web isn't. MyIOS apps are fine. Maybe updating Metadata?
Not sure what you mean. Plex can take quite a bit of time updating Metadata after you create a library. What exactly is going wrong?
gso
Apr 26, 2020Guide
I did like you said and deleted my Music folder in the NAS/ReadyCloud. Then Cloned from Carbon Copy Cloner back into the NAS directly from my iTunes/Music folder. My ReadyNAS & iTunes have the same files but there is a folder called "Various Artists" which I moved all of the data to the root level, so the folder is now empty in both. But in Sonos & Plex & on IOS apps there is 169 albums (the same albums are in the root level.
- gsoApr 26, 2020Guide
I moved the data to the root level of the Itune folder before Cloning to NAS.
- StephenBApr 27, 2020Guru - Experienced User
I still don't understand what you think is wrong. How many albums should there be?
- gsoApr 27, 2020Guide
Never mind. It's just iTunes way of saying there are several artists. I was concerned there were multiple copies of sam music but it isn't so. Thx.
