s4mb4
Apr 25, 2013Aspirant
missing unrar in the new OS6
enable SSH. log in and add the following line to /etc/apt/sources.list deb http://ftp.us.debian.org/debian squeeze main non-free save it and then run apt-get update then just apt-get install...
s4mb4
Do this instead.....
enable SSH.
deb http://ftp.us.debian.org/debian wheezy main non-free
then just apt-get install unrar
enable SSH.
Dave_Ams
Aug 28, 2015Tutor
All,
What version of Debian is 6.3.5 using, is it still on Wheezy? I would like to add the non-free unrar.
David
- Dave_AmsAug 30, 2015Tutor
All,
I attempted the procedure above to update unrar but I get the following message:
oot@penguin-nas:~# apt-get install unrar
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following NEW packages will be installed:
unrar
0 upgraded, 1 newly installed, 0 to remove and 60 not upgraded.
Need to get 109 kB of archives.
After this operation, 245 kB of additional disk space will be used.
Get:1 http://ftp.us.debian.org/debian/ wheezy/non-free unrar amd64 1:4.1.4-1 [109 kB]
Fetched 109 kB in 0s (129 kB/s)
debconf: delaying package configuration, since apt-utils is not installed
Selecting previously unselected package unrar.
(Reading database ... 18245 files and directories currently installed.)
Unpacking unrar (from .../unrar_1%3a4.1.4-1_amd64.deb) ...Unrar is still the same version as before:
root@penguin-nas:~# unrar
UNRAR 4.10 freeware Copyright (c) 1993-2012 Alexander RoshalOn this system I'm running 6.4.0-T112
Can you also install the .deb unrar package thru the webgui?
- mdgm-ntgrAug 30, 2015NETGEAR Employee Retired
# dpkg -l | grep unrar
- Dave_AmsSep 23, 2015Tutor
All,
Sorry for not reacting any sooner, I found an other way to install the latest unrar:
http://www.cyberciti.biz/faq/open-rar-file-or-extract-rar-files-under-linux-or-unix/
# cd /tmp
Download from rarlab, check the version first
# wget http://www.rarlab.com/rar/rarlinux-x64-5.3.b4.tar.gz
Unpack
# tar -zxvf rarlinux-*.tar.gz
# cd rar
Check that this version runs and is the one you want (adding ./ before the command makes sure you execute the version in your current directory.
#./unrarBackup your current rar and unrar versions:
# mv /usr/local/bin/unrar /usr/local/bin/unrar-old
# mv /usr/local/bin/rar /usr/local/bin/rar-old
Copy new version to bin
# cp rar unrar /usr/local/bin
# cd ~
You should now be able to run the new version from anywhere
# unrar
The reason I needed a new version was that unrar crashed as soon as I started to unpack the large multipart rar files I downloaded of the internet. A quick test this morning showed that the newly downloaded version works better.
Dave
