ksor1's avatar
ksor1
Netgear DUO admin site ??
I've had this NASdrive for years and it has worked well - I renewed the discs 1 time - nice !   I had it running under Windows 10 for most of the years - but had the problem that I could NOT get ac...
  • StephenB's avatar
    Jun 26, 2025
    ksor1 wrote:
    I sometimes just run the RAIDAR program
    It'd be helpful to know if you have the original Duo, or if you have the Duo v2.
    The original Duo
    • says ReadyNAS Duo on the front panel and in RAIDar
    • runs 4.1.x firmware (RAIDar should tell you that)
    The v2
    • says ReadyNAS Duo v2 on the front panel and in RAIDar
    • runs 5.3.x firmware
    ksor1 wrote:
    the NAS is still assigned 192.168.1.2
    Then you can access the NAS web ui using https://192.168.1.2/admin.  But you need to use Firefox, and set security.tls.version.min to 1 (browse to about:config and search for the setting).
    If you don't recall the admin password, the default for the original Duo is netgear1.  The default for the v2 is password.
    ksor1 wrote:
    I used the 'name' \\192.168.1.2\media" to get access in Windows 11  ... and in fact it worked for 3-4 days
    It'll be easier to sort this out after you get admin access.
ProSupport for Business
