JamesHorton
Jun 17, 2022Guide
Netgear ReadyNAS NV+ (RND4000 V3) has died
Hi, everyone I was hoping for some advice, please. My Netgear ReadyNAS NV+ (RND4000 V3) has died. It fails to switch on and boot. I've checked the PCU which is dead. I believe it is beyond the cos...
JamesHorton
Jun 26, 2022Guide
Thanks for your help. I bought a similar second-hand model and put my drives straight in and booted up with no problems.
The only issue I have now is the http & https SSL issue to access front view. But at least I can access my files over wifi for now.
Kindest regards,
James
cathcam
Jun 27, 2022Guide
You can download a copy of Firefox 78.9.0esr release that will still allow you to access the ReadyNAS using TLS 1.0.Directory Listing: /pub/firefox/releases/78.9.0esr/ (mozilla.org)
It's also possible to update the certificate and software but a lot more complicated than having a back level browser sitting around.
I also had my power supply on my NVX go. I bought a power supply from the UK and fitted it myself, it was very simple.
++Mark.
- StephenBJun 28, 2022Guru - Experienced User
FWIW, you don't have to go back that far. Firefox 94.0.2 will also work (and perhaps a slightly newer releases also).
- JamesHortonJun 28, 2022Guide
Firefox 94.0.2 release appears not to work for me also? I'm on a mac if that makes any difference?
I think I'll check my network settings. As I only can connect via wifi. Very odd.
Thanks,
James
Sorted. Netgear default password. Using Opera, to gain access to Frontview. It may work in other browsers? I would have to try them next.
Thanks, everyone.
Kindest Regards
James
Firefox 78.9.0esr release appears not to work for me? I did consider a new power supply, but it was cheaper for me (half the price) to buy a second-hand Ready NAS, also not knowing if it was only the power supply that was the only issue, I didn't want to waste money.
Thanks,
James
