creesy
Oct 10, 2015Aspirant
New NAS Long Re-Synch
I just booted up my new RN104 with 3 disks (3TB Each) turned it on updated the firmware (Had issues wouldnt boot had to do USB recovery) 2 of the Disks were used one was brand new all are the sam...
meverz
Oct 10, 2015Apprentice
You can use the NAS while you wait for it to sync. However, it will make everything (the write speed and the sync) slower, and you want have the benefit of reduncancy until it has finished syncing anyway. So it is usually best to wait till it is finished syncing, and then copy your data across.
MarcusF
Oct 10, 2015NETGEAR Employee
Yes there will be performance hit if try copy in data while sync finishes but with OS 6 one of the advantages is redundancy will happen during intial sync. It will ensure that data written to array is striped and redundant.
This is only true during initial sync. Sync during expansion or rebuild later does not have sam functioanlity because the data is already in place.
