FerociousNAS
Jul 02, 2024Tutor
Power On ReadNAS 422 and reboots...
Hello all, Power On my RN422 and after 30 seconds it reboots and then fully boots up. Also have a RN524 doing the same but after two reboot it fully boots up. Other then that they both work fine....
Jul 02, 2024Guru - Experienced User
FerociousNAS wrote:
Power On my RN422 and after 30 seconds it reboots and then fully boots up. Also have a RN524 doing the same but after two reboot it fully boots up. Other then that they both work fine. I updated the firmware to 6.10.9 but no change. Checked the fan and power supply too.
Anyone else experienced this issue?
Odd. Download the log zip files, and see if you can figure out what is happening. Maybe start by looking in dmesg.log.
FerociousNAS
Jul 08, 2024Tutor
Thank but the logs show no errors.... 🤔
- StephenBJul 09, 2024Guru - Experienced User
You should be seeing something in the log zip around the time of the second reboot.
FWIW, I am not seeing this behavior in my own ReadyNAS.
- FerociousNASJul 09, 2024Tutor
ok I got the zip log file this time.... Looked at the dmes.log. Not really sure what I'm looking for? 🤔
How are you shutting down the NAS?
The errors in dmesg indicate that the volume is resyncing and also that the usb drive was not properly unmounted. So I am wondering if you doing a clean shutdown when you power down the NAS.
