Pete10p
Feb 22, 2018Aspirant
ReadyNAS 102 sending to 64.233.167.109
I have two ReadyNas 102's running 6.9.2 firmware. My home LAN is setup to drop all traffic from and to the internet to be dropped. According to my router’s logs, both 102's are continually at...
Feb 27, 2018Guru - Experienced User
Pete10p wrote:
I dont know how to do that
Then try opening the firewall and provisioning a DNS server in the NAS, and see if the emails come through. If they do, then lock it down again.
Pete10p
Feb 28, 2018Aspirant
Thanks for your help.
I've tried that, and I have deleted the email config in the ReadyNas and its still trying to send something. One of my ReadyNas's is sending to what looks like a Google address and the other has a destination of 8.8.8.8.
For the moment I have changed both ReadyNas to static IP and a non-existent DNS server to stop the flood of denial messages coming from the firewall.
- StephenBFeb 28, 2018Guru - Experienced User
8.8.8.8 is google's public DNS server. Many people do add a DNS entry for that in their NAS network configuration, but AFAIK it is never applied automatically.
You could try the brute-force approach and do a factory reset (reconfiguring the NAS and restoring all the data from backups)
- Pete10pMar 01, 2018Aspirant
Thanks for your help but I think it’s time to give up and leave the config as a non-existent DNS server. At least the router firewall log isn’t overwhelmed anymore.
