Pete10p
Feb 22, 2018Aspirant
ReadyNAS 102 sending to 64.233.167.109
I have two ReadyNas 102's running 6.9.2 firmware. My home LAN is setup to drop all traffic from and to the internet to be dropped. According to my router’s logs, both 102's are continually at...
Feb 28, 2018Guru - Experienced User
Pete10p wrote:
the other has a destination of 8.8.8.8.
8.8.8.8 is google's public DNS server. Many people do add a DNS entry for that in their NAS network configuration, but AFAIK it is never applied automatically.
You could try the brute-force approach and do a factory reset (reconfiguring the NAS and restoring all the data from backups)
Pete10p
Mar 01, 2018Aspirant
Thanks for your help but I think it’s time to give up and leave the config as a non-existent DNS server. At least the router firewall log isn’t overwhelmed anymore.
